Can you apply a keyed switch to a cdi ignition? the switch im looking at has two conections as my kill switch does so would i be able to apply one wire from the keyed switch to the positive then ground the other wire just as my kill switch does? From the motor comes the positive wire with a double connect one wire to kill switch, other to coil. on kill switch are two wires one grounds itself. i could wire a key switch the same right. ill have a pick in a moment, camara died :think:
