upnorthbacon
- Jan 28, 2005
- 35
- 0
Klotz and Honda oil questions?
Went to pick up some of my usual Klotz premix and they have Klotz watercraft blend for premix or injectors. I always used R50 (I think that was the version it was premix only) will I be ok with the watercraft blend? What is the difference between the injector recommended oils and premix only oils? Also the guy at the shop talked me into using Honda Pro-Honda HP Trans Oil SAE 80W/85W for the gearbox. I read the back and Honda states it's for 2 stroke gearboxes. Is this good stuff or should I drain it and run regular synthetic 10w30?
