I'm about to rebuild my 200 exc. The KTM manual says to use a hotplate to heat the case halves to 150*C and tap on the case with a mallet and the bng should drop out. The mech at H&H told me they use a torch instead of a hot plate.
Has anyone out there done this before? Did it work out well? Did you use propane or map gas? About how long did it take to heat the case half so it would expand that tiny skosh?
