Strick
1,782
Fellow pumpkin riders/rebuilders;
Base Gasket Thickness. Do I have to remove the cylinder and measure, and order the correction combination of base gasket(s), or is there base gasket 'kit' you buy, and choose the right combo from the options given?
For those of you who read this board and the other (KTM) board, please excuse my redundancy.
Strick '99 KTM 300mxc, AMA & BRC member
[This message has been edited by Strick (edited 02-25-2001).]
Jeff Gilbert
2,969
I bought Cometic and it came with 2 base gaskets.
"Nature Boy"
Motowrench
23
HELLO FELLOW KTM FANS!!
YES,,, You should measure the thickness of the base gaskets you removed. This will give you a starting place in selecting the right thickness of gaskets. Hopefully you have a good dealer to work with and can get extra gaskets, and just return the ones you don't use. Get several sizes, and ALWAYS MEASURE the Dimension X (deck height) Set to KTM specs according to the manual. Some models require a special tool for measuring this, so you might want to check with your dealer reguarding this procedure. Don't rely on the measurements of the new gaskets for calculating the distance, as the new gaskets will crush when you torque the cylinder down.
GOOD LUCK! TEAM ORANGE CRUSH!!
GlennP
311
Strick,
Measuring the old gasket is not the best way, as its compressed slightly during installation. I rebuilt several 300 EXCs, just finnishing one last week, and this is how I do it:
First get a good metric caliper. Clean old gasket material from all surfaces. Put the new (or cleaned original) piston on the rod without rings(is eaiser for this temp installation). Put the cylinder on the cases without a gasket and hand tighten a couple of the base nuts. Move the crank with the flywheel to TDC. Carefully measure the distance from the edge of the piston dome to the cylinder deck. This is the required base gasket thickness for dimmension X = 0. You should round off to the next thickest available size as it won't be exact, and X must be between 0 and .1mm.
After your power valve is cleand and reassembled (locktite on all fasteners) set the main flap height to 46mm from the cylinder deck to the center of the flap edge when the valve is fully closed. This is dimmension "Z". If everything is done correctly, the PV control rod will snap on the ball joint without any vertical preload after the cylinder is torqued down. Good Luck.
Glenn
'00 GasGas XC250
LoriKTM
Super Power AssClown
Oct 4, 1999
2,220
6
New Mexico
Hey Strick,
When my husband did the top end on his bike (1999 250MXC)last year, he was able to order a top-end gasket kit from the dealer (don't remember the cost). It had a bunch of different thickness base gaskets in it. I believe the kit # is listed in the parts manual, I think it's the same kit for 250's and up.
Strick
1,782
What does everyone think of Wiseco? I hope your input is positive. It's already paid for and on order.
Steve F.
10
Wiesco made a batch of pistons for the 300 that the front piston skirt was to wide so check it with your stock piston to make sure you got the right one.If you got one like I did & the piston skirt is wider than the stock one you will no upon start up when the skirt makes contact with the crank webs(sounded like a very bad lower rod bearing)
Steve F.98 300EXC
MikeS
716
Hey Strick
You will probably get mixed opinions on pistons. Personally I found the stock KTM pistons to be very long lasting. Maybe 2:1 with equivlant ring changes in My applications. But for atleast a 2:1 price difference for Wiseco you get 2 fresh pistons instead of one.
Also I think Wiseco may offer 2 ring versions for some bikes. That some prefer.
The Wiseco is usually lighter and allows quicker reving. Most are also forged and require a little more care on warm than OEM cast pistons.
As for oil and break in I used the same oil as a run normally. You can always Contact the Oil Manufacture for their official recommendation.
Mike S
Strick
1,782
Mike S. - Thanks! I am going to replace the top end every year. My compression read 160 this weekend, and I have ran the bike a full season + one race. I think it's time. I look at it like that old oil filter commercial: 'You can pay me now, or you can pay me later.'
A riding buddy of mine waited too long recently, and had to have the cylinder resleeved, because of the damage.
Motowrench
23
STRICK,
I have to agree with MikeS, that you will get mixed opinions about the pistons, but the stock KTM pistons are forged units also, comparable to the Wiseco's. The KTM pistons are definatly more expensive, but seem to last much longer than the Wisecos, without the worry of fitting right!!
The most important part of any engine is a good Air Filter, with a tight intake tract, that is maintained well!!
Motowrench
GlennP
311
There are several other threads on this subject. I think proper fit has a lot to do with it. An OEM Wiseco GasGas piston will last as long as an OEM KTM piston, but there are 4 mico sizes to achieve a precision fit, and only 1 replacement size for a KTM.
Glenn
'00 GasGas XC250
Strick
1,782
Motowrench, et.al.:
I am a maintenance freak!! Anyone who knows me on this board or elsewhere can attest to that. One ride per air filter summer & fall, two rides max during winter & spring (I have 6 air filters). Gearbox oil changed every other ride, or every race (Mobil 1 15w-50 synthetic). Gas is never kept for more than a couple of weeks, and I use 50/50 race gas at 40:1 MX2t.
I will mic the Wiseco piston as soon as I get it as well as the cylinder. I will also check tolerances with the piston inside.
My question to all commentors is this. Why is Wiseco O.K. for all the other bikes out there but not KTM? I can't imagine the piston being an inferior product. KTMs are not the typical type of rebuild. With Z & X dimensions to be considered, there seems to be more to it than other 2-strokes.
The biggest reason I ordered Wiseco is, I don't feel I get straight answers at my local KTM shop. Can you imagine a parts guy telling you that at 2000 miles, and 160psi compression (~200 new), that I should just wait to put a new top end. He said until the compression drops to 125, or I feel a power loss should I consider a new top end. HELLO! I think he was looking for a little replating job. Or maybe a total meltdown including bottom end. <Keep in mind this is the same guy that sold me a Delta I, as a Delta II reed assembly.> I already had the bike partially disassembled anyway to put in a Delta 2 reed cage, and do some deeper inspection after my last race, so now is the time!
I envy you guys that are treated fairly (and Honestly) by your local KTM dealers. The only other reason Wiseco is attrative is ease of getting the parts quickly.
TexKDX
747
Strick, pull the jug and replace them with the quantity and color that came out. The thicknesses are color-coded. Green and white. The dealer sent me two whites and a green, mine had one white and a green. That is what I put back in. Next time I'll just order a green.
MikeS
716
Strick
I don't have hard scientific data to determine which is superior. The KTM , I think is a Mahle and is very high quality, it has a coating that helps prevent scuffing,plus it seems to be thicker/denser.
Some say Wiseco loses it dimensions faster. Being lighter suggests that material was left out somewhere. I never let that happen any way by changing the piston after every other ring change or when it goes out of spec. If you are a low maintance person then the OEM KTM is a better choice IMO.
Dealers are sometimes tough when it comes to suggestions. I have alot of dealers within a hour or so travel and sometimes I consult all to get the best Average answer. A couple of them race everyweek and service their own stuff so they usually have valid info.
Hope you get it together soon , it is a shame to leave that pumkin just sit around....
Mike S
GlennP
311
The stock KTM piston is an ELKO, an excellent forged unit that I believe is made in the Netherlands. From my experience with three 300 EXCs, They last from one to two seasons, but get pretty loose at the end of the second season. We tried a Wiseco in my buddy's 300 EXC, and got one season out of it with good performance, although top end noise was greater than with a new stock piston, telling me clearances were on the loose side. In a GasGas, there are four micro sizes of Wiseco (OEM) available to match different bore tolerances (A,B,C,D)like the KTM #1 and #2 cylinders and #1 and #2 ELKO pistons. When you use a Wiseco KTM replacement, where does the size fall? In #1, #2, or in between? When we tried one, there was only one size available.
I don't like to keep a piston in longer than 1 season anyway. Try the Wiseco and monitor compression and noise to guage life. Measure it and your bore to determine clearance, and use a three point bore mic if possible. I did not have good enough tools at the time we used one. The GasGas motor has good compression and very little mechanical top end noise after 1 season, so I can't say that the piston is inferior to the ELKO.
Glenn
'00 GasGas XC250
erdento
Strick: I just replaced the piston and rings, too. For the 2000 KTM the piston is a Vertex part--the name was cast into the underside of the crown. KTM had been using Mahle which is very high quality but expensive. I opted for another Vertex as a replacement although the Wieseco piston seemed to be a good quality replacement. To obtain the correct base gasket thickness, I removed the existing ones (there were two stacked together), measured them, and took them to the dealer to obtain correct replacements. I was unable to obtain the correct left hand side power valve cover gasket. I'm glad I checked the piston; there was considerable blow by on the skirt and indications of a too lean state--small burn spot on the exhaust port side of the crown and burnt oil on the underside of the crown. I think one season is about it between replacements.
Strick
1,782
Thanks everyone. I should have it pinned together and riding by Saturday. The one season philosohy, I feel is sound, as do other responders. Regardless of what the local KTM dealer says.
erdetno, Too lean? Maybe a self-proclaimed jetting expert can help you with your woes. We will talk next time we meet up. Are you riding this weekend? If so, we can talk then. We can discuss your jetting, and my recent rebuild.
[This message has been edited by Strick (edited 02-27-2001).]
Motowrench
23
STRICK
Don't get me wrong, I'm not accusing you of low maintenance practices!! In fact, I am also a major maintenance freak, and know where you are coming from! Actually there is such a vast amount of information about this subject, that you couldn't even begin to put it in words in this little box. I can only offer the information and knowledge I have gathered since becoming a PENTON/KTM Freak in 1977!
I hope that everything works out ok,,and your back to slinging some dirt by the weekend!!
GOOD LUCK!
Motowrench
Strick
1,782
Motowrench, et.al. So check this out for bad news: I yank off the cylinder when I get home from the office, and what do I find. A full blown meltdown above the exhaust port. Bad enough to where the Nikasil has actually melted down onto the power valve. Plug the piston, at the same location, was chipped below the second ring. The plug is a nice tan color, and I really don't remember over heating the bike. Oh well, I guess I will have to buy or borrow another bike to race with on the 11th. I don't think I can get it replated by then.
More details: the head was so clean it looked like someone had just buffed it. The cross hatching in the remainder of the cylinder was still nice, the power valve was amazingly clean. I this Mobil MX2t is to be of credit for that! So much for waiting to rebuild until 125psi!
John Blaze
29
Strick - Sorry to hear about the engine troubles! Maybe you should stop riding that poor little 300 so hard.
Your welcome to ride my XR for the race coming up, but I don't recommend it. She's a beast. I hope you find a bike to race. Good luck!
John Campbell - '01 Service Honda CR500AF
'99 XR442 (ForSale)
Motowrench
23
STRICK,
HOLY SMOKES!!! Sounds pretty bad!! The condition you describe is definately heat related. Be sure and check the crank seals, timing, possibly the ignition box, etc. I know that KTM has had ignition problems in the past, but they would generally cause hard starting or just quit. Check anything that would possibly cause the lean-out condition, carburetion, intake boot, etc.
Also, something that we have had trouble with, is the gas and oil separating in the cold weather. We use Maxima 927 & Super M, and the 927 Castor separates in cold weather.
Just have to make sure to keep the fuel mixed good. I don't know why I'm telling you this,,,You guys probably don't have much of this cold stuff in Nevada!!
I hope you find the problem, and get the KATOOM back together soon!!
Good Luck,,,, Again
Motowrench
Strick
1,782
Oh, it just gets better. The radial play in the connecting rod specs at .021-032mm. Whats mine at? .70mm. The whole darn motor needs a rebuild.
Motowrench: the lean condition is probably right. My last race 2/18, was a 95 mile Hare and Hound. Two very long straights one was at 2000' above the starting elevation, and it was snowing. The 178 main just wasn't enough for 6200', and 32 degrees. Darn weather! The forecast was high 40's
Blaze: I'll have another bike by the weekend. You're not going to keep me out of that race. My next door neighbor has already offered up his 380. If I didn't have to have the cylinder replated, I would have the 300 ready.
Steve F.
10
Strick I think you got your inch & mm mixed up or at least I hope so.
I think you mean the radial side play is supose to be .021"(.54mm)to .032"(.82mm) so if your measurement of .70mm is actually mm you should be OK. Just checking
Steve F.98 300EXC(with .028" radial play)
Strick
1,782
Steve,
You are right, and the manual is wrong. I kid you not, the '98 250/300/380 KTM service manual reads: .021-.032mm. Which should read in mm: .53-.81mm or .021-.032 in. You were the first person to actually catch this. The only thing the two local bike shops could tell me that the amount of free play was normal. Thanks for bringing it to my attention.
Back to the story: I should not have been such a pessimist! The cylinder came clean of melted piston with Muric (sp?) Acid. The cylinder is very lightly scored. I have all the parts ready to put it back together tomorrow, if I can free up the power valve. I am going to try easy off. So, all seems O.K. for now.
Thanks to all for the replies and support!!
