kx 250 compression
I have a 2002 kawasaki kx 250. I'm having a hard time getting it to start. Especially when it is cold. I was wondering how much compression should my bike have? And also how low can it get before you need to rebuild it?
Ive got the same bike, 02 KX250. the dude i bought it from said some after market stuff was done to the engine, i wish i could say what was done. but i have a hard time starting mine too. once i get it started and warmed up, its easy to start. i think i almost broke my foot the last time i tried to start it. (i left for iraq so its been a while since i rode it last)
Woodsquest
I love DRN!
Check your intake reeds. If they are stock, then they are probably frayed out a little or chipped. That will cause hard starting.
this is what the kawasaki service manual says on a kx 250 for a 2003 -2005
KX250:
Item Standard Service Limit
Cylinder Head
Cylinder Compression (Usable range) – – –
825 ∼ 1 275 kPa
(8.4 ∼ 13.0 kgf/cm², 119 ∼ 185 psi)
Cylinder Head Warp – – – 0.03 mm (0.0012 in.)
Cylinder, Piston
Cylinder Inside Diameter 66.400 ∼ 66.415 mm (2.6142 ∼ 2.6148 in.) 66.46 mm (2.617 in.)
30 mm (1.18 in.) below of the
cylinder head)
Piston Diameter 66.336 ∼ 66.351 mm (2.6116 ∼ 2.6122 in.) 66.19 mm (2.6059 in.)
Piston/Cylinder Clearance 0.049 ∼ 0.079 mm (0.0019 ∼ 0.0031 in.) – – –
Piston Ring/Groove Clearance 0.025 ∼ 0.06 mm (0.00098 ∼ 0.00236 in.) 0.16 mm (0.006 in.)
Piston Ring Groove Width 1.01 ∼ 1.03 mm (0.0398 ∼ 0.0406 in.) 1.11 mm (0.044 In.)
Piston Ring Thickness 0.970 ∼ 0.985 mm (0.0382 ∼ 0.0388 in.) 0.90 mm (0.035 in.)
Piston Ring End Gap 0.25 ∼ 0.45 mm (0.0098 ∼ 0.0177 in.) 0.75 mm (0.030 in.)
Piston Pin Diameter 17.995 ∼ 18.000 mm (0.7085 ∼ 0.7087 in.) 17.96 mm (0.707 in.)
Piston Pin Hole Diameter 18.001 ∼ 18.011 mm (0.7087 ∼ 0.7091 in.) 18.08 mm (0.712 in.)
Small End Inside Diameter 22.003 ∼ 22.012 mm (0.8663 ∼ 0.8666 in.) 22.05 mm (0.868 in.)
