FruDaddy
2,854
Fill it up until you can see it through the glass (while vertical and level). Clean the dirt off of the clutch cover and you should see the glass. It usually takes about half a liter. Before you ask your nest question, I like Bel-ray 75 wt Gear Saver in mine, but there are several threads here about what type af trans oil to use in a 2-stroke.
FruDaddy
2,854
500cc is half a liter. Sometimes residual in the trans will mean that you put less that 500cc in. That's why I always use that little window. Buy a liter and it will get you through 2 oil changes.
