cyclebradd88
- Apr 19, 2003
- 48
- 0
I am almost finished with a KX fork conversion on my KDX200. I am using my KDX front wheel and axle, with a KX Caliper ( because the KX fork uses a different hole spacing for the mounting.) Anyway, the issue is this…
How do I determine the correct alignment between the brake rotor and the caliper? It looks as though one pad is stationary, and the dual pistons move the other pad. Do I space the wheel to narrowly miss the stationary pad? Do I center the Rotor between the two pads when the caliper is completely open? I will appreciate your input.
