Does the PC2 pipe have more clearance between the pipe and the frame where it bends right out of the exhaust port? Maybe the FMF?
I am looking for a pipe that once installed is further away from the down tube. The reason is becasue with the KDX motor in the KX frame, the stock pipe is too tight and touches the downtube before it fully seats in th exhaust port.
The pipe comes out of the exhaust port and the bends to the left around a down tube. the stock KDX pipe touches teh KX frame that down tube and does not seat fully in the exhaust port. So I need a pipe with a longer section before it bends.
I can weld a section on I know but I figured aftermarket pipes may be a bit longer.
You will know if your aftermarket pipe on your KDX is further from the frame down tube than the stock pipe was. If you are not sure, post a pic of the area, I can compare it to the stock pipe down tube clearance.
