KX100 Powervalve oil seal question
kawakid
39
There is an oil seal where the KIPS powervalve operating rod goes into the powervalve chamber. My question is which way this seal goes in. One side is deeply grooved - does the grooved side face in or out???????????
Thanks for your help!!!!!
DEANSFASTWAY
1,192
Spring side of seal faces into the cylinder, make sure you have the gears timed correctly or you could have troubles with the governor balls falling out inside the motor. New 04 linkage peices are spring buffered. Team Green News has a bulletin on this, and setup tips try www.teamgreennews canada.com Good Luck
sampson
35
I had that happen on a bike I just bought on a traid I got it home and the trany locked up but the bike was still running. we dissmanteled the lowerend and found the powervalve balls in the lowerend.
is the kx100 a decent bike? this left a bad tast in my mouth for the kawies
