99 640 lc4 - will only start if in neutral, clutch doesn't matter. How can I override this, where is the wire that senses the neutral. Is this common to newer KTM's??
Must be just the newer ones, my 97 starts in gear with the clutch pulled in.
There's a switch in the clutch perch,I'm not sure where the neutral switch is, but I think it's under the countershaft sprocket cover, just above and behind the lower oil filter housing.
