leaky carb?????
my 99 yz 125 carberator pisses out fuel when my bike is not running,(its not just a dripping motion its a staedy stream) and the only way to stop it is to turn the fuel off. what is the problem and how can it be fixed on???
thats an odd thing my ttr 125 l was doing the same damn thing it keept running fine but leaked
i took off the carb today and where the choke lever connects in i saw signs of BAD fuel im gonna take it appart and clean it with contact cleaner
elf
Check your float needle, theres either some dirt in it or the little rubber o-ring needs to be replaced.
I am having the same problem with my bike. I talked with one of the local techs and he said my floats
were set to high. I'm going to adjust it down and see if that works.
