MauriceF
Dear all,
from the Netherlands: I'm looking for a lightcoil (is that he english name for it?) to fit on my ignition. Can't find it, maybe someone knows how to make it?
Thanks a lot............
Dragmeistr
149
I was looking to do the same thing. I installed the electrex stator, motor starts fine, but when I hook the light up the bike dies. No one there can seem to tell me what is wrong???
dirt bike dave
5,348
Can't help you with your problem Dragmeister.  But your misfortune is a good opportunity to point out the eline system is completely separate from the bike's ignition.  So with the eline, there's no chance a lighting problem can effect the ignition.
Good luck getting yours fixed!
Dragmeistr
149
Fixed mine up last night. It appears that you cant run a 50 watt light on a 60 watt stator. Tried a light with a 45 watt bulb and the Electrex unit works fine. Pretty easy to install and once you have the appropriate light, it works well.
tedkxkdx
393
How did you order your electrex, ie was it through a US dealer of sorts? Please tell me which one?
FRESH VIDEO
