Lost my manual!! How much oil?
I think my dad lost my manual already... I cant seem to find how much motoroil to add into my crank case. It's a 2003 cr 125. any help would be great. thanks
Originally posted by Bet On Red
nm.. i forgot it's written on the side of my crank case. *DOH*
Written? dont you mean stampted?
Good Homer impression.
I remember good someone told me Rob Healy used to just throw the whole quart in the case.
I had another buddy named Tomo fill it all the way full!!
it's stamped but i also wrote the exact amount with a sharpie marker after i got the bike home :) That way i dont have to waste brain space and also dont need the manual! lolz
how much oil do YOU put in?
My guess would be about 700-900 ML, or a little short of a quart.
Either way there should be a check bolt in the case (on the clutch side)
and you would fill it up until the oil comes out of that hole. Don't just use motor oil on a CR use a good quality motorcycle oil, or gearsaver oil that was designed for your bike.
DT.
DT.
i added about half a quart in.. When i drained the oil it was about half also... This bike is new... the shop added the first amount of oil... so stick with half or go with almost one quart?
