Hey Guys,
I have an ' 00 CR250 and the lower shock needle bearings are beginning to have some "up and down" play in them.
All the needles are still there and it is lubed up pretty well. Nothing seems to be broken either.
If I need to replace anything ....do you just buy new needles or do you have to press out the whole joint ??? This bearing set is actually on the linkage but lower shock mount passes through it.
Any pointers or advice from fellow owners or guys that have cured this problem will be appreciated.
Thanks ,
Donnie
Thanks ,
Donnie
