Michelin Trials tire - phenomenal!!
EK
66
I have spent a many hours and miles running the Michelin X-11 Competition rear trials tire on my '01 GasGas 300XC. I wanted to share what I have found.
First of all, I am an intermediate level rider who does mostly trail riding. I do not compete. I weigh about 250 lbs gear on ready to ride. I ride an ‘01 GasGas 300XC, that puts out 40+ HP at the rear wheel. Most of my riding is on trails in wooded areas in Western Washington and Oregon. Most of the soil is hard clay, with a lot of rocks and tree roots. Most of the year the clay is wet. When it is wet, the clay is very greasy. Next to ice, wet rocky and rooted infested clay is the most difficult trail condition to ride on.
As an Engineer I like to look at things objectively. To make sure that I objectively evaluate rear off-road tires for trail riding, I run them on a couple of nearby *test* hills in the woods of Western Washington. In the fall, winter and spring these hills are wet slimy clay and rocks, making them very challenging to climb. I have used the Dunlop 739, Dunlop 739 AT, Dunlop 756, Michelin S-12, Michelin H-12, Bridgestone ED78, IRC ix05h. I have had the best knobby tire performance with the Dunlop 756, Michelin S-12 and Michelin H-12. The hills are steep enough and technical enough that I can just make over the top of the hills with a good knobby as long as I maintain momentum and a good line.
On those same slimy wet clay and rock test hills with the Michelin X-11 rear Trials tire, I could accelerate up the hills and in some areas even lift the front wheel. The grip was so much better, I was astonished. Further, I have climbed some even steeper wet clay hills with the Michelin trials tire that I could not climb with any knobby tire. To this day, I am still impressed at where I can go with the Michelin trials tire. The Michelin trials tire works very well in loam. It is excellent on fireroads. It works quite well in sandy trails. It works well in snow up to about 4 inches deep and on snow covered rocks. It is outstanding in pure rocks. It even works well in the deep mud bogs if you torque it along, rather that massive spinning like a knobby. I even ran it a few times on a track. It worked fine there as well. I have run it at speed on tracks, fireroads and in the sand. It is stable, smooth and handles very predictably at any speed. It is DOT rated so you can even run it on the highway on a dualsport.
I installed my first Michelin X-11 trials tire early spring ’01. I put 820 miles on my first one. It started to lose its effectiveness at about 700 miles. It has worn down about 40%, but not a single knob has ripped off or chunked, even with full throttle on rocks and gravel/rock logging roads. There are cracks at the base of the knobs where the knob meets the tire, but they are all intact. As a reference, I would normally get about 300 miles on a Dunlop 756 before knobs were so well rounded, worn down and missing/chunked out that I changed it.
The key to riding with a trials tire in slimy mud is NOT to spin. Get it to grip by starting real easy, torquing along a gear high and steadily roll on the throttle without minimal spinning. The bike will move forward surprisingly well. If you just nail the throttle it will wildly spin just like anything else. A trials tire grips, where a knobby digs and throws dirt/mud. In the dryer conditions you can use full throttle and be rewarded by outstanding hookup and easy wheelies.
Compared to a knobby the Michelin trials tire is:
> Much, much better traction in just about every trail condition.
> Much easier to maintain a line, up or downhill
> Much better rut crossing and staying out of ruts.
> Much easier to start out while on a hill.
> Much better rear braking and improved rear braking control especially on downhills.
> Much smoother rear tire ride, especially on rocks. The tire adds more shock absorption resulting in less bouncing and chattering.
> Feels squishier and flexes more on cornering. However, it is very predictable and stays hooked up very well. In the really slimy conditions it positively blows away a knobby in the corners. You can very easily and predictably brake slide the rear tire in corners if you desire.
> Clears mud much better. The tire easily clears sticky clay mud at speeds above 10 to 15 mph as long as you are going forward and not just wildly spinning the tire. It clears mud much better than a Dunlop 756 or Michelin H-12 on the front!!. The trials tire will be clear of mud while the front tire is packed half full of mud.
> More sensitive to tire pressure. I have found about 8 psi works best all around. Even a few psi higher will noticeably reduce its effectiveness. For very muddy conditions you may want to go a little lower, like 7 psi.
> Offer outstanding rim protection. I regularly smash through rocks and roots mile after mile. The front rim with a 756 at 15 psi comes back with black rubber marks all over the edge of the rim from the severe impact of the tire on the rim. The rear rim has not a single rubber mark at all when running at 8 psi. It is amazing. I run a heavy duty tube. So far no flats, in spite of all rocks I have hit.
A few additional notes: The Michelin X-11 is DOT approved. TT designates Tube type TL designates Tubeless. Either will work, as you will need to use a tube anyway, unless you have a trials rim for tubeless tires.
Cautions:
1) A trials tire will require some change to your riding style, as it gets its traction from gripping as opposed to the digging and throwing done by a knobby. Try not to spin as much and it will reward you very nicely.
2) On hills be careful as you may find your front end wheeling up much easier and looping out more easliy.
3) Tighten down the rimlock(s) very, very securely or it will slip on the rim due to the exceptional grip and low pressure.
4) Cracks will likely appear at the back side base of the knobs, due to braking. Cracks will also likely appear first at the front side base of the knobs, due to acceleration. Do not panic, the knobs are quite secure for offroad high power application. I have never had a knob rip off.
5) The tire does not work well on steeper hills in deep loose dry material like sand or cinder.
For me the trials tire is the only way to go. :)
Eric in WA
’01 GasGas 300XC
RTKLR1
36
I have been using the michelin trials tire for about 500 miles now and have found it to be as described, the only thing is that when it is really slimy it spins alot, I HAVENT had it at 7-8 psi yet, I will try that since it works so awesome everywhere else,I have also ridden 2 520 ktm's, a 200 ktm and a 300 gasgas and then went and bought one,awesome at gold bar and walker valley,what really surprised me was how good at belfair, was able to power up through the roots and pick really weird lines, it doesnt work good in deep snow, but what does???
Camstyn
2,247
Wow, I'm surprised to hear this. I never thought a trials tire would be very capable of trail riding, let alone being very good at it!
smb_racing
Master of None
2,085
how does the tire work on non snow covered ground that just happens to be frozen solid?
EK
66
The Michelin trials tire works much better on frozen ground than any knobby I have used. It also works noticeably better on ice than a knobby - it is more stable and tracks much straighter under power. Keep in mind on ice you need to go very easy on the throttle.
Eric K
'01 GasGas 300XC
Patman
Pantless Wonder
Hint:
Run your valve stem lock up against the cap to keep the tube from tearing at the stem if the tube were to slip on the rim if the rim lock fail to keep things secure.
danjerman
122
Just where are you testing these tires, Jones Creek? Sounds like the landscape you were describing fit it exactly, man I hate those rocks!
EK
66
I ride Jones creek, Tillamook forest (Brown's camp/Jordan creek), McCubbins Gulch, Gifford Pinchot and other areas. Jones creek and Tillamook forest have the most rocks, roots and slimy clay.
With a trials tire you may even find yourself looking for some of the larger rocks to ride over since the tire sticks amazing well on rocks. The trick is to find the big rocks that do not move under the impact of the bike :eek: Even if you don't like going over big rocks, the trials tire will provide much more stability over the small rocks.
Eric K
'01 GasGas 300XC
Patman
Pantless Wonder
They're kinda' like having Spiderman's powers :)
Hondaman_06
75
I've read a lot of good stuff about this tire. Is this tire really worth 2 times as much $ or more than the price of a quailty knobbie? I mean does it really perform that much better to justify it's high cost?
FOX426
41
EK, good article. Do you have any input on how the X-11 works on pavement? What about wear on pavement? Wondering how they would really be for 50/50 dirt,street riding. In the 70s we used tires for Dualsports (Enduro Bikes called then) very similar. Thanks for info.
EK
66
As far a trials tire for the front of my GasGas, I have not done it. The reason being is that the front tire I currently use on my GasGas an IRC ix05h works extremely well (much, much better than a dunlop 756) so I am satisfied.
I do not ride on paved roads. However, here is a link to report a friend of mine wrote citing some of his experience with the Michelin trials tire on the trail, track and road:
http://www.thumpertalk.com/bike/pages/pr_michelin_x11.htm
I was talking to trials rider a few months ago. He knows a guy who desert races using a trials tire on the rear. He has done very well.
Bottom line, I have no plans of buying anything other than a competition trials tire for the rear of my motorcycles. The tire definitely far outlasts and outperforms a knobby.
Eric K
'01 GasGas 300XC
'00 Sherco 290
