keychange
- May 4, 2010
- 7
- 0
I picked up a flange mount Mikuni (measures 24mm) on eBay and wanted to try it as a replacement for the Amal in my 1976 Montesa. It appears to be an old VM model as fitted in a 1971 DT1
Slide looks new and the carbie looks in good general condition.
I can get it started but it is way too rich with fuel blowing back out the air inlet (filter not connected) and I mean spraying out and no way it will idle ... well it did once then it went silly again. It is clean as a new pin... I have played with float but at no stage has there been fuel overflowing. I have replaced the setter o-ring with a generic (good fit) could this be the issue?
When fitted is sits leaning forward on approx 10degree angle. I just can't figure out what's happening but it must be something obvious that I am missing.
