I think Ivan is correct. If the two oils are "compatable" as you run the fuel through, your combined ratio will slowly change to 32:1 after you run through about a tank and a half. You know what I mean? That's why it would be better to try to run your tank empty or drain it so you will see an immediate difference. SuperM is an excellent choice.
