2stroke
399
I've got a post 2000 YZ125 that I'm looking at. The frame prefix is as follows JYACEO.
Can Anybody tell me what year this is? They seller isn't quite sure but I want to know.
MXSparx
Mr. Meltsomeglass
Jul 25, 1999
3,724
71
NoVa
the 10th digit in the vin indicates year.
2stroke
399
aww nuts. I only wrote down the alpha prefix on the frame #. Hmm. Ok, thanks...
What about the engine number? is there a way to tell from that?
drgriffi1 said:
How do you get 2000 from a Y? Someone is blowing smoke up yer a$$. Either the person saying 2000 or the person saying you can tell from 10th digit.
They are both correct. And they are the same person. You are the only one blowin smoke :blah:
rmc_olderthandirt
1,533
8
Starting around 1980 dirt bikes sold in the USA had to conform to the same VIN numbering scheme that automobiles use. Most of the digits are coded to indicate key information. For example, the first letter is the country of manufacture (J= Japan in this case), the second letter identifies the manufacturer (Y =Yamaha).
The 10th digit is the key for the year. The system was set up for starting in 1971, so "1' could equal 1971. After 1979 it goes to letters, so "A" would be 1980. They skip the letters that could easily be confused for numbers or another letter, so I, O, Q, U, and Z are not used. Thus, "Y" is the code for 2000. Starting in 2001 the codes start over, so 1 could be 1971 or 2001 (hopefully you can tell the difference....)
Rod
