Well I pulled my swingarm/linkage off my (new to me) 98.
Main bolt came out with just gentle tapping. Nothing like in this thread http://dirtrider.net/forums3/showthread.php?t=84203 (although there is some light corrosion, need to see what the bolt looks like after I clean it up and if it's bad replace).
Definately needing replacement:
- left side swingarm - bearing/collar/seals
- linkage/lower shock - bearing/collar/seals
- linkage/center - bearing/collar/seals
A few questions:
1) How often does the upper shock bushing need replacing (I didn't remove the shock fully yet)? I notice the Pivot Works shock kit includes both the lower bearing and the upper bushing but the much cheaper Moose (A29-1002 shock lower) kit just includes the lower bearing.
2) In this thread kdx220freak claims "can get the [Moose] swingarm and linkage bearings for a kit of $85" http://dirtrider.net/forums3/showthread.php?t=123283
When I looked, the Moose swingarm (A28-1064) was around $45 and the Moose Linkage (A27-1036) was around $80. Pretty similar to the PivotWorks kits. Is there a way cheaper source as otherwise I'm considering just replacing the above only with OEM.
A few questions:
