More help please...1999 YZ400F.
Well.. Got my bike started today it idled for about 2 minutes then I was going to do one lap around the parking lot and come back and check the oil. I got about 50 feet from the truck and heard a scrathing,screeching sound for about 2 seconds and that was it. LOCKED UP. I put into nutral and pushed the bike back. I cant even kick it because the kick lever wont budge. This is my first
experiance with four strokes. When this happend on my 125 I had sucked a gasket and it messed up my crank? Is this a cold seise? It was cold when i did it, wut i let it warm up. What should i do, and ho much do you think this will put me under for?
Thanks for the Help, Keith
biglou
#2
If you're "lucky", you might have fragged the clutch basket and/or plates. Common problem (so I'm told) is for the fragments to get tossed into the kick start gear and bind things up. Drain the oil, pull the right side cover off and see what the clutch looks like. If it's fragged, you'll need to pull the right side case cover off and clean out the millions of tiny (and not so tiny) particles that have scattered themselves into the backside of the case cover. Taking this case cover off is easy, btw. Remove the rear brake pedal, and take the oil line loose (one 8mm head bolt). Then take the 8 or so bolts off holding the case cover on. You should drain the coolant first, too. Drain bolt is on the water pump cover, which is mounted to the front of that case cover.
Same thing happened to Thunder33's bike a little over a year ago. I thought for sure the small end of the conrod had let go, which I have also seen happen. Turns out the clutch basket just let go. His gave a little more warning though, it was making some not-so-good noises after riding around for a while. He made about 1/4 lap or less after that, and it was locked solid, but would still roll in neutral.
