I did change the damper oil as we talked about in a previous post and feel confident that all the air is out. Set on full hard, with 7wt. fluid, I can definetly feel it working. BUTTTT! It is damping harder when turning right, than left. Quite a bit harder in fact. Turning right it will nearly stop and turning left it has some resistance, but will still blow right through the damping with some mild pressure on the bars. Any ideas? I did make sure the arm is at 90 degrees to the shaft and it feels like it's centered as far as when the damping kicks in from side to side, just that left turn isn't damped as hard. Could there STILL be air in there?
