fuzzy
447
Trailer in the background.  Cheap bolt together Long Chih.  Both of my full-size dirtbikes will fit on it w/ the z50 in the middle.  Can tow it with my Jetta.  Will fit in a parking space sideways along with my Jetta.  Use it for local trips when I don't want to tow the 6x12 enclosed with the 5mpg big block suburban :)
CdnKDX
Worked up a small trailer, carries four (two big, two small).....also small enough to stand up in the garage, out of the way.
http://www.bikepics.com/pictures/081684/
88KDX
97
Please send more pictures of your trailers if you have them. I need ideas on how to change my jetski trailer into an ATV/motorcycle trailer.
TR
179
CDNKDX, nice trailer, very neat. What sort of suspension system have you got ? Most trailer use the leaf spring design or those rubber suspension system.
Regards
TR
tedkxkdx
393
Hopefully there is an image of my trailer that was built with a Corolla rear axle.  Note the different way I tie down the bike via the tires instead of h-bar.
If you cannot view the image you can go to my gallery and see it since I posted it there too.
