Bill Hibbs
- Aug 25, 1999
- 537
- 0
So Friday after the team harescramble at DW I had a flat (that's why Jaybird and I didn't win it ;) ). Anyway, I take it to the truck to have them throw on a new tire and tube. Drop it off, come back an hour later and it's still sitting there. The Rear axle was frozen into the hub. Here's the lesson:
If your rear wheel feels loose (which mine actually wasn't) OR you see a tear in any of the dust seals (yea, mine was torn) REPLACE IT IMMEDIATELY! The grease washed out of the non-drive side bearing (very wet Summer here in Ohio). The bearing got EXTREMELY hot cooking the grease. The bushings and bearings and everything welded to the axle. What a nightmare. After hours of hammering on the bushings with a cold chisel I finally got it apart, destroying EVERY component in the rear wheel. Axels aren't Cheap!
So, hopefully you can learn from my mistake and not let this happen to you. :thumb:
