ranger_5_0
- Apr 1, 2009
- 8
- 0
hi i just got an 87 kdx200 and am trying to get it running properly. ive tried search but i figure ill get more personal responses this was. ill try to provide as much info as possible. also this is my first 2 stroke so maybe i just dont think its right. it seems like power is somewhat lacking in bottom end especially first gear. i hit 2nd and it will pull the front wheel right up. carb has been gone through me about 4 times and a guy i know who actually works at a motorsports shop. stock jetting, needle set on middle clip position. i think i got the float situation squared away atleast it quit leaking fuel out the overflow. it appears there is a part mission from my carb might be part of my problem too. 16065 holder-carburetor, needle jet is the description on the diagram im looking at. im assuming it keeps the needle jet from moving up in the carb body? and it looks like it is made to go between the needle jet and main jet? am i correct? i apologize if some of my terminology is off as im new to this. also i get what seems to be a lean runaway where the kill switch will not shut the bike off but as long as im in gear the bike doesnt rev too high and it will just drive itself slowly, then pull in the clutch and it screams until i dump the clutch in gear to stall it. things ive checked: reeds look good, new petcock, new fuel filter and fuel line, new spark plug, compression at 135psi, supposedly new topend not very long ago. its doesnt start very easily either its about 60 degrees F here and it takes around 10 kicks usually. sorry for the long post just trying to get this all sorted out. edit also not new to working on engines/ carburetors just new to 2 strokes. thanks for any info you can give me.
