KDXgeezer
7
Every time I try to jump, I land on the front tire. I'm 46 and I cant handle too many more crashes. Do I need to pull back on the bars after I'm in the air? Guess I need some coaching from the 10 year olds doing 50 foot tripples at the local track.
RM_guy
Moderator
7,045
208
North East USA
There have been several threads on this subject if you can find them but here are a few tips.
- Keep the gas on when leaving the take off ramp. It will shoot you higher but the front wheel will stay up.
- Get over the rear fender more to help keep the rear end down.
- When you realize that the front end is dropping in the air, spin the rear wheel and it will pull the front wheel up.
- Body english in the air can help to raise the front too.
- Try not to hit the jump where a lip has been worn in. Aim for a smoother part of the jump off to the side of the take off ramp.
Good luck and practice on smaller kicker jumps until you feel comfortable with the techniques that I discussed.
jk_151
One other thing to check is that you are standing on the pegs in the run up to and on the face of the jump. Sitting on the face of jumps pre-loads your suspension causing your back end to 'bounce' up off the face of the jump therefore lowering your front end.
If you plan on sitting down off the face of a jump: hold your gas pinned until you are in the air. This will level out the 'bounce' and put you higher in the air. This technique is rightly called "seat bouncing".
If you're going to stand: just find a smooth line of the the jump, stand up, pinch your seat with your knees and roll the throttle on evenly.
Jaybird
Apprentice Goon
6,452
Charlestown, IN
I too am an old guy who found the same problem. When I was a kid I never even thought about it, jumps just happened. Now that I think about it constantly....I find that I can do a jump without gripping with my knees and my front wants to dive, if I DO grip with my knees on the exact same jump, the bike jumps fine. I hate the taste of dirt!:D
Jimmy!
137
Leaving the ramp under a little power is good. If you coast or chop the throttle too soon, the front will drop as soon as it clears the ramp & the rear will want to kick up when it leaves.
KDXgeezer
7
Thanks everyone. I'll try these tips next time out. I think I just need more throttle and need to stand more on pegs. At what point do I shift my weight back over rear fender? The kids seem to do this as soon as they are in the air.
cr250john
122
Been there (recently)
KDXgeezer
I'm 49 and ride a '00 CR250. This is my first dirt bike that I purchased last year. I too have experienced the same problems as you. I recently have been able to (almost) clear a 15-20 foot table top. OK you younger riders, go ahead and laugh at us.
I found that I had a habbit of chopping the throttle near the lip of the jump out of fear of going too fast and over jumping when just the opposite was happening. The front end would dive and not look or feel very good.
The past couple of weeks I got the "stones" to hold the throttle on the jump face and the bike actually behaves MUCH better. It makes a nice arc through the air. I also have found it better to be a gear higher, say 3rd instead of 2nd. That way I'm not "on the pipe" and risk hitting the power band as I leave the jump causing the front end to launch into the sky.
I keep my helmet over the cross bar when I jump. I'd be careful leaning back AND holding the throttle on the face of the jump. Try a "normal" standing position first while holding constant throttle and see how the bike "flies", then adjust your body position.
So we older riders are just more cautious I guess. We have to go to work during the week and can't afford time off work because of an unexpected "get-off".
Take care... you're not alone.
Be sure to give us an update. I like to hear what others have tried and the results.
MikeT
4,112
11
Re: Been there (recently)
Originally posted by cr250john
KDXgeezer
Well put John. I think the neutral standing position is best with medium throttle. I have noticed something similar to this when riding my friends bike. When I jump my YZ125, the front goes high in the air frequently. I have to be very aware of it and make sure I'm over the bars to keep it down when jumping. Now when I jump my friends 93 CR250, the front ALWAYS nose dives so I have to move back when jumping and rev the bike in the air.
I'm not sure but I think the CG of my bike is back farther and the CR has its CG more forward.... Not sure though.
KDXgeezer
7
Maybe I'm trying to do stuff with a KDX 200 that it was not meant to do. This is a woods and enduro bike and I know it doesn't have the same beefy forks as an MX bike, or the extreemly fast throttle response. But I think I should be able to do some moderate jumps. Does anyone else use a similar enduro bike on MX tracks just for recreation?
MikeT
4,112
11
No, no, no.
The KDX is a fully capable bike. Its all in your technique and body positioning. You need to practice and you'll get it.
No one has mentioned this yet but we are all assuming you have the clickers on your suspension set up properly. For example if on the forks you had the compression set at FULL SOFT and the rebound set at the slowest rebound setting. All that along with your shock set up with the quickest rebound and stiffest compression.... That would contribute to you nose diving, I think you get the picture.
Make sure your settings are pretty "neutral" Your bike is COMPLETELY capable.
KXKen
535
Though I agree with this advice be carefull because this combo not done properly will do just the opposite and send the front end up so high you'll have to let go of the bike. I did this last year and it hurt for 6 weeks.
KDXgeezer
7
I believe the KDX 200 has only a compression damping adjudtment on the bottom end of the fork tubes. No rebound adjustment. It set towards the stiffer end of range. So I think thats ok.
Back shock I left at factory setting as I believe the factory sets it up for a 150 lb rider. I am 150 lb.
Bike is probably set ok, rider just needs to work on technique. At 46, I'm a tad old for picking up dirt riding, but I'm havin a ball and my 10yr old boy is a major grin factory on his Suzuki JR80.
Reeko
67
My $.02 ,
You should rarely get over the rear of the bike on a jump unless there is a kicker that tends to kick the rear end up. Small take off ramps, where the front is already off while the rear is just starting to compress will kick the rear up, You NEED to be on the throttle to prevent this.
Normal jumps should be jumped in a central/neutral body position. This allow you to compensate when the attitude of the bike is unexpected. If you consistently jump nose low, you are probably choping the throttle (or else sitting on the jump face, another no no unless you are prepared and on the throttle).
Jumping with your weight back is dangerous in my opinion. You have a higher chance of looping out if this is done BEFORE you leave the jump. Shifting your weight around should really be done after you are in the air to compensate for problems.
You will notice a lot of fast guys seem to be over the back of the bike. This is ussually because they are going faster than needed to clear a jump and are braking on the jump face. They shift weight back since they are not jumping under power. This is an advanced technique (IMO) and should only be done after you become comfortable jumping (and are comfortable making mid-flight corrections).
Jaybird
Apprentice Goon
6,452
Charlestown, IN
When you see A/B riders twords the back of their bike during a jump, it's probably because they are pushing the handlebars forward. This actually makes it look like they are moving twords the back, when in fact they are preparing the bike for landing.
MikeT
4,112
11
This is turning into a VERY good technical thread. I am learning too.
46 years old? I plan on riding then. You'll get it but don't do anything you don't feel comfortable with. It's better to ride another day then not to ride at all.
RMFanatic
99
jumping
I am a 1 1/2 year mxr at the age of 38 (I have been on bikes since age 10 roughly) and I agree with the majority of the info that you have received, but I want to add a little to the mix if you don't mind. I recently went through several bike switches (125 to 250 to 500) and I think that if your kdx is anything like a 125 I would suggest staying on the throttle a little longer and taking the neutral position while standing. You may find yourself nose up, but that is a lot esier to compensate for than nose down. A little rear brake will bring the nose over, but it takes a lot of panic rev to bring the nose up. You choose your situation. I personaly do not like having the throttle pegged while looking at the dirt and my front fender on exactly the same plane.
Gordon Spraggins
Mxr's for Christ
