Woa,Morvo said:This happened to me a while back, but instead of helicoiling the crankcase thread with the engine in situe, I separated the two cases because I was worried about small metal fragments getting into my engine and facking everything up! Wish I just done it the simple way now *sigh*
uts said:Woa,
that's pretty crazy man.
Morvo said:I separated the two cases because I was worried about small metal fragments getting into my engine QUOTE]
If you load the tap with heavy grease and blow compressed air into the oil filler hole while tapping, all the chips will blow out and stick to the grease.
Self-tapping bolts will work in many cases but on some engines the material is too thin at the drain hole and the tapered self-tapping bolt will split the drain hole. The heli-coil uses a special tap made just for heli-coils. Once the insert is installed the thread is back to the stock size and the stock drain plug and washer can be used.
