oil leak
little Kawi
16
I have a oil leak where the output shaft comes out of the tranny/engine. I need to know if it is easily replaced or if it is a real pain in the backside. Any info will help.
76GMC1500
Uhhh...
It's relatively easy. If it's large enough, run a sheet metal screw into it and just pull it out.
little Kawi
16
Thanks alot for the links, they helped out alot. I think that it is just a o-ring at least iI hope it is.
Red Ryder
104
I can't believe it's just an O-ring, I'm sure you know what your talking about but it just dosn't make much sence. It seems like the o-ring would just wear out very fast, unlike a seal it is constantly compressing against the shaft by a little o-shapped spring.
Cookies are required to use this site. You must accept them to continue using the site. Learn more…
