Some of the old DeCarbon style shocks used a resealable bung in the reservoir that you inserted a hypodermic needle into for gas filling. You should find a phillips head screw in the middle of the reservoir. Remove this to expose the bung. Pressurise to 175psi. Removing the seal head can be a problem if you're unfamiliar with the design. Yell out if you need help.
Terry
