Cr125 Nutter
14
Ready to build my topend after have it all replated along with a new piston but iv just notice i have only 1 center dowel on the bottom of my barrel that helps line up the barrel when fitting it to the piston.
Is this still ok to just use the 1 i have got or do u need to dowels.
Thanks guys
16,902
If it's designed for two dowels (and it most likely is) then you need two dowels. If the barrel doesn't stay stable and center the life of the piston, rings, and crank will be seriously compromised.
