Firewalker
42
i currently have an 2006 yz265, my cylinder got scored so i will not be able to put another 68.5mm piston in. i would like to be able to by a larger piston and just get my sleeve rebored for it but i cannot find a larger piston and ring set pn.
i see that max power lists a 71mm piston and tghey claim to only use wiseco pistons. i checked wisco website and they don't list anything larger than a 68.5mm
thanks
Jon
Max Power has some pistons custom made by Wiseco, and they charge a HUGE premium if you want to buy one.
Unless the cylinder is totally destroyed your 265 can be replated so you can use the same piston you have been.
Firewalker
42
i see that the 1998 yz250 has a 69mm piston, what would the difference be between a 1998 piston and a 2006 piston. my assumption is the different powervalves in the engines would mean that they would have to change something on the piston but i wouldn't know what, unless overall height is different because they use different stroke between the 2.
I don't have that level of knowledge on the various years of YZ pistons, sorry. Hopefully someone else will be able to help.
