Play in linkage to rear shock (250EXC)
Chouca
31
On my -97 250EXC there is more than an inch play if I move the tire up and down before the shock starts moving. I guess this might be a problem with the bearings in the linkage, what KTM calls the Pro Lever System. Have any of you guys any experiences of this and how to fix it (disassemble/assemble) in the most clever way???
Montana300
123
You have worn bearings in your suspension linkage. If those bearings haven't been serviced since new, you will probably have to replace all the bearings [typically roller type], and possibly the roller shafts [name?] also.
Dismantle each joint of the rear linkage and remove and replace as necessary.
FRESH VIDEO
