Hello,
I recently purchased a used 2006 YZ 250.
I took the whole thing apart for cleaning and inspection. Unfortunately, before I read the details about using the little pin when removing the power valve, I did it without the pin. (I learned of the pin upon reassembly)
The manual only says damage WILL occur if the pin is not used. Can someone out there tell me what happens if the pin is not used. The guiloteen part of the valve seems to work fin manually, however the guides to not move enough to get the side valve moving when I operate them by hand.
