My guess is it will be the crank. Quit trying to run it/kick it and pull it apart to inspect as it's likely only going to get more expensive with each attempt.
Thanks Chili
I will have to look into that.
You have been a great resource for me. All our bikes are having issues all at once. Ih well, like they say...When it Rains it Pours LOL. I will also be posting some pics of the YZ85 clutch next....
I was always under the assumption that if the bike needed bottom end work you need to bring it to a shop because there was alot of special tools required to "split the case" and rebuild the bottom end. Is that true??
From the sounds of it Chili has you pointed in the right direction. It also sounds like you should look at pulling the engine and sending it to Eric Gorr or take it to a local shop. If you have a factory manual you might attempt the lower end but only you know if that's something you are comfortable with.
You can make tools that will do the job but it is a bit more involved than a lawnmower engine as you have a transmission to deal with. If you have the factory manual look in the book and it will show the tolls you need. Then do a little thinkin' and you should be able to replicate them. You might also search here on DRN as I recall somebody doing just this.
In all honesty I have the ability to borrow the tools and do the work myself but Eric and Rich do such a great job and know more details than I do that it makes no sense to me to mess with it. We currently have a BMC 1500 engine on the stand in the garage that is a project that I know most of the tricks for so I am doing it.
