2004 YZ250
this weekend at my race i had my bike seize up for the fourth time in the last six months. first time it was minor, had the cylinder wall honed out and installed a new piston. i had a ring break the second t time which gouged the cylinder wall, so i had it resleeved. third time the piston exploded into pieces. i pulled apart the top and bottom end, we found a broken gasket (called the gasket, air cleaner cover on the parts fiche). coolant seemed to be leaking at this point and i thought that this was causing the bike to overheat and possibly leaning out fuel mixture by allowing air into the bottom end (not sure if this is possible). i am not a huge fan of resleeving, because i have heard that the piston runs a little hotter and i thought this was a factor in my problem. so i ponied up the pennies and bought a new cylinder and cylinder head and had the whole motor reassembled, new gaskets and all. I did one race, which was a wide-open sandy gp race w/ a lot of fast fifth gear sections. rode the bike hard, no problems. this last weekend had another gp and on the first practice lap about 3-4 minutes in the bike just died, wouldn't start back up and had very little compression. we took it back to the truck pulled off the head, saw what i thought was a mild seize mark, but nothing major. we ended up putting some premix on the cylinder wall to help seat the rings, put it back together, and the bike fired up with compression close to normal. so in the race the last lap bike seizes up in a wide open sections (complete seize kick starter doesn't move) the gp had some pavement sections that were wide open, but i wasn't holding it wide open the whole time and i was hitting the kill switch repeatedly.
sorry for the long post, but i'm just frustrated and can't see what is causing the problem. any thoughts or suggestions would be appreciated.
Gabe
Gabe
