canyncarvr
- Oct 14, 1999
- 4,005
- 0
Try this: Set the air screw to highest idle. Do it on a thoroughly warmed up bike. Turn the AS out (slowly..say one 'tick' in 10-15 seconds) one slot width at a time (say 1/16 turn) until the bike reaches highest idle. From that point, turn the AS in a tad under 1/4 turn.
Oh...and take note of how far out that 'highest idle' setting is.
Say again how you service your air filter.
I'm myopic here I realize.....but this '..couldn't tell a difference..' part regarding AS settings is a problem that must be resolved.
Is your fuel 'old'?
If you happen to have a gallon of berryman's around....take your carb apart and give it a good soak, blow out every passage with clean/dry air.
Again, IF there is no difference in throttle response with any setting of your AS you're either far off jet-wise or something is plugged.
What's your elevation? RH? How does the bike response change with a 45 pilot? Does your plug load up (bike 4-strokes) after a fairly long idle time (long downhill)?
And if that's not enough for 'ya.....what is the difference when the bike is good'n hot with a BR7ES (or BR8EG) in it?
There is an answer. Hope you keep after it.
***edit*****
Gearloose's post got 'inbetween' (I didn't see it). Didn't mean to repeat what he said...but he said good! ;)
btw..'RH' is 'relative humidity'
Is your fuel 'old'?
***edit*****
