pullin teeth
What link chain will I need to add a single tooth to the rear sprocket (over stock on a 200)? I assume a single tooth will add just a hint more snap??? Thanks.
CaptainObvious
Formally known as RV6Junkie
If you are mid-way through your adjustment (or more) you should be ok with the chain you have with only one tooth. One tooth will add some snap. Three would add some more!
I fixin to get a new chain. The stocker crapper is all used up. Will 108 be long enough for the +1 tooth?
CaptainObvious
Stock the bike comes with 13/47 gears, a 110 link chain plus a master. I'd order a 112 and remove a link or two if you have to.
CaptainObvious
What year KDX? I assumed an H model.
CaptainObvious
Duhhh, I looked up the spec for my bike, an E3.
