Does anyone know what the connecting rod center-to-center distance is for the PW 50? Also does Yamaha sell any GYT-R parts for this bike and if so what are they?
sorry don't know the rod length center to center. Have not seen the racing goodies for the Pw. I'd guess its because the only racing that is popular for this bike is AMA class3 and it is a basically a box stock class where the only legal mods are basically gearing and bar standoffs.
Jasle;
I need the rod length to input into a computer program. This bike is raced in MX. I really don't know yet about buying parts. I need to know what is available.
What I'm really interested in is what limiters are incorperated in the bike and what mods can be preformed to increase performance. Since this is a new racer I don't want to overwhelm him. Thanks
The real limiter is the suspension. It sucks. As soon as she starts jumping you need to stock up on lower steering stem bearing races. They crack like eggs.
As far as the bike goes motor wise the gearing is too tall, the compression is too low, the carb too small...You can get the right gearing $175 at yamaha, or $60 onE-bay different reeds, bore the carb, Increase the compression. Change the porting. get the fmf pipe. When it comes down to it you can easily spend a grand and make it a so-so mxer. When you look at the other two racers in the same class (class 3) you will find the Cobra PW3 and the KTM Mini Adventure OI. Both of which totally smoke the PW50. What I'd suggest is just using the PW50 as designed. A great un-intimidating bike to learn on. And when your rider is ready to make the jump get a bike that comes stock with great suspension. The suspension will hlep here riding way more than ANYthing you can do motor-wise to the pw. The best bang for your buck will be changing the ring and pinion. After that maybe playing with the clutch springs. The clutch hits when the rider even thinks of turning the throttle. If you increase the RPM's a bit its a big advantage. Like I alluded to you can just chop one coil off the spring and rebend it so they fit and it will help a bunch. For a better suited hard hitting spring you will find some for under $20 at www.paxraing.com and a spring guy in OK on E-bay. If you have the facilties to do your own milling then have at the head. They really wake up with some compression. Most guys take material off the cylinder but I have seen a guy on E-bay claiming his heads work best.
