I have a 99 KX 125 and just today, the shock decided to blow the seal, what luck. I can rebuild shocks and just have never done it on a shock with high and low speed comp adjusters. How do you remove this? Also, when bleeding, I put the bleed bolt to the highest point and then just crack it open to let air out? Also, last question, how do I hold the shock shaft still while I remove the nut that holds on the valving so that I can replace the seal? Thanks.
Aaron's web site
Aaron's web site
