I recently pulled the seat cover off my Honda CR250 to shave down the foam and fix some holes, and now I need help to reattach it. Do I just staple directly through the seat cover into the plastic, or do I do something else?
Along the edge of the seat cover, there was some stuff that looked like double-sided tape. What is this and does it need to be replaced?
Also, Im shaving 1" of foam off the top to lower the seat height, is there anything else I should do to make it stretch across the part I removed?
Will a regular staple gun (the kind where you depress a lever and a spring fires the staple) work to reattach it or do I need an air powered one?
One other question - will adjusting the rear shock let the bike sag more? Is there anyway to tell how much to adjust it to make it sag more so I can fit better on it (I have the serivice manual but I couldnt find any info other then where the adjusting thing was)?
