Aug 28, 2012
i have a 2002 rm 85 that fouls plugs all the time!!! I run 36-1 gas oil ratio and it smokes some but it drips oil out the exhaust! Is it to low of a mix??? Or do i have to get the carb adjusted like the changing or the reeds Any help please
IndyMX
Crash Test Dummy
5,548
Amo, IN
Pick a ratio and jet accordingly. It's not fouling and dripping spooge because of the amount of oil you are using, it's doing it because you're jetting is too rich. or in otherwords, your Air / Fuel ratio is wrong. Too much fuel.
And there is no magic bullet here. You just need to buy jets and start working to get it right.
There are a quite a few threads on here that detail how to properly jet a bike. It's not hard once you understand the concepts.
arnego2
271
If your top end is not new you might have a look first in getting that set up correctly. With a worn out topend trying to fix your jetting will be hard, to say the least.
