i have a 96 rm250 and the frame is bent, and i found a 99 rm250 frame and i asked around and some ppl said it should inerchange with no problems.. does any 1 no if it will work ? befor i buy it off ebay ... thanks ..
um i know that the 96 had a problem becuase they welded the rear shock mounts the wrong way , but as far as that i think there the same , but im not positive
