Is the cable routed properly? Are there after market springs installed? The correct number of plates? If the lever on the case is adjustable, it will pull easier if it is set at a right angle to the cable. And I suppose notches in the hub or basket could make it hang a little. Suzuki's usually have the easiest pull?
