JD_MXRacer
411
my dirtbike doesnt idle very well. even after its warmed up it will barely idle in neutral and if i have it in gear w/ clutch pulled in all the way it will die.
i was going to adjust the idle screw on the carbeurator but it is completely stripped. like almost a circle. do you know any way of getting it out?
joey450
59
It took a lot of cussing :yell: and a flat tip screw driver when the same thing happened to me on a crf 70 my son use to have, i used a flat tip screw driver that was a slightly larger than where it was stripped and a small hammer and LIGHTLY tapped the end of screw driver untill it grabbed the inside of the stripped head of the screw and held light pressure against it as i turned it,and by some miracle it worked.
