doogiebares
- Apr 9, 2005
- 8
- 0
I have a 1994 YZ250. I just did a top end and went back in with Boysen Pro Series reeds. Other than the Weisco standard piston, my bike is stock. (except the FMF TurbinCore2 sparky) I have decided to install a pipe to pep up my ride.
Here is the help I need. FMF Fatty, Gnarly or Pro Circuit Platinum.
I ride in the AZ desert. Mostly trails and gravel pits. I think I want the low and mid performance increases. Top end is fine as well, but I don't ride wide open in 5th gear often for more than a few moments at a time. I just like to climb and the dry stream beds.
If you had my setup, which would you get?
Thanks much for YOUR input.
