:think: I have been trying to locate shim kits to rebuild my shim stack for the shock on my 98 YZ400f. The shock has been revalved with a RaceTec gold valve and delta valve, but I am still having problems with the shock bottoming badly.
Where can I go to order the shim kits to rebuild the compression stack to get a little stiffer ride, and avoid the bottoming problem.
By the way the shock spring has already been replaced. :aj:
