terry hay
200
If your shock seems soft and it is riding low the first thing I would suggest is that you check your sag figures. You may not have enough preload on it. If you need to increase the preload this will increase the rebound speed so you may also need to adjust the clicker at the bottom of the shock. Try to run around 95mm of race sag on that particular bike.
Terry
