Can the Showa forks off of a 02 RM125 be directly installed onto an 03 RM250 in place of the existing Kayabas or is a triple clamp swap required??? Are there any other modifications necessary?? Thanks
i am pretty confident they will, the top clamps fir both models, make sure you check the spring rates though since i couldnt find anything heavier than 0.44s for my 02rm125
LOL- i will take some measurements later if i remember. i actually never swapped them over but often though about it. i might want to look into the spacing of the axle though if i were to go from RM to YZ
