ryanfoley
129
HOw do you guys remove these caps? Ive seen tools in the mags but havent had any luck finding them. Do you guys just use a huge socket? if so what size?
Ryan
mxneagle
320
Do a search on this subject it was recently discussed. The cap is octagonal so a standard socket doesn't fit. I made my own but you can buy one.
JTT
1,407
First you need to loosen the top clamp bolts. You "can" use a large adjustable wrench, but risk damaging the caps (very soft and small shoulder). Like mxeagle, I made my own tool out or a piece of 1/4" aluminum plate. Simply marked on the 50mm octagon and cut it out. It's not pretty, but I was in a rush at the time and it works fine. I kept saying I was going to make a better one, but never got around to it.
The best and simplest way is to simply buy the right tool. It's available from Motion Pro, Race Tech and numerous other places.
ryanfoley
129
Hey thanks alot, right now i dont have any access to any tools to make my own so i will check out those companys.
