Squeaking noise?- maybe water pump?
layoutd
61
after a couple of times gentley laying the bike down on the trail :) , i started to notice a squeaking noise coming from the engine. only happened at certain rpms. i believe that it is coming from the water pump. if it was a car, i would definitely say water pump. i guess i have a bearing going out. sound like a fair diagnosis? doesn't sound too bad, should last for a little while. would the fix be to just replace a bearing, or the whole impeller assembly? any kits out there?
