Standing Up?
Hey Guys,
I bought a 2003mdl YZ250 about 3 months ago, it is my first bike, so i'm just learning to ride it. I don't seem to have any problems, i am jumping 70 - 80 foot tables, 30 foot doubles, all fine but when i comes to changing up gears while standing just feels awkward. I can't seem to get my foot under the lever and when i do my foot is on a bad angle (bent forward, so therefore i have to lean my left leg forward). I've tried moving my gear lever higher but then it's just too high and i can't ride. What should i do? Is maybe my gear lever too short and i need it extended? I wear 'Tech 8' boots, but so does everyone and they have no trouble...
Let me know what you think, any advice will be appreciated!
Thanks.
drzgod
Lifetime Sponsor
I wear Alpinestar Tech 6s. They are a very large boot because of the armoring on them. I purchased an extended shift lever, made all the difference.
rickyd
Hot Sauce
When shifting while standing, i kinda lift my whole leg up some, a quick jerk..
Rick
High Lord Gomer
Poked with Sticks
#5
Ike tells us top run our shifters level with the top of the footpeg. If you're upshifting, you should be accelerating, which means you should be rather far forward and getting your boot under the shifter shouldn't be a problem.
Chief
I used the notches on the spline, then heated the lever and bent it up or down to fine tune it. I have to lift my knee to shift while sitting, and can shift more comfortable while standing.
tedkxkdx
Lifetime Sponsor
You don't have to get your whole foot under the shifter. I got very comfortable with using the side of my boot at the sole to catch the shifter. If you are new to your boots than it will take time to learn the feel. You would want to learn the side of boot technique anyway since when in deep ruts you don't want to put you foot below the bike frame rails.
